Hi guys, Im new in this forum and i don't know if someone has posted this thread before. I would hear and see if any of you have been facing double click issue on Razer DA 2014? it basically means when i perform single click it sometimes becomes double click effect just like an example where i click on a folder(select), it tends to open that folder(double click action). Any solution of this issue?
thanks in advance and feel sorry for my poor english level. @@
https://linustechtips.com/topic/265465-razer-deathadder-double-click-issue/
2 options if warranty is up.
open up the mouse and oil the microswitch or replace the microswitch inside.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
well, if it's still in warranty, contact razer and find out if they'll cover it.
I've never dealt with their support.
You could try taking some compressed air and blowing it between the buttons on the mouse.  Other than that you can get the mouse replaced.
This solution worked for me in my Logitech G400  :D. Gonna try my mouse for some more time if it will happen again.
