Fan adjustments
Solved by W-L,
Okay, have you used the software? Just wondering if you know for sure that you can do that.
Thanks.
I haven't really used the software in depth before personally but I do know it includes that as a feature if you want a fairly in depth overview tweaktown has a good video, the one generation older but the new one includes previous features:
