Problem with H100i
Go to solution Solved by h7779,
operating system?
shut down, turn power off, wait 30sec, reboot and retry.
Thanks for your help, but I found a fixed for it, had to edit the registry.
Just got the H100i and it seems that Corsair Link is not recognizing the pump and the two fans attached to it. I have plugged in the USB of the pump into my mobo USB header but it is still not showing up.
Help please thanks.
Motherboard is the MSI Z97 Gaming 7.
CPU: Intel Core i7-4790K Quad-Core Processor | CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler | Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard | Memory: Corsair Vengeance 16GB | Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive, Seagate 4TB 3.5" 5900RPM Internal Hard Drive | Video Card: EVGA GeForce GTX 970 3.5GB ACX 2.0 Video Card x2 SLI| Case: Corsair 450D ATX Mid Tower Case | Power SupplyEVGA SuperNOVA 750 G2
https://linustechtips.com/topic/265189-problem-with-h100i/
operating system?
https://linustechtips.com/topic/265189-problem-with-h100i/#findComment-3605336
And what exactly? Maybe it would help out other people having the same problem.
"Step 1. Search REGEDIT.exe
Step 2. Local Machine\System\CurrentControlSet\Enum\US­B\VID_1B11C&PID_0C04\(FIRST FOLDER) then Device Parameters
Step 3. Back up all 7 Reg Files BEFORE EDITING!!!
Step 4. Edit File Names [AllowIdleIrpInD3] [DeviceSelectiveSuspended] [EnhancedPowerManagementEnabled] right click each one and press Modify..
Step 5. Change all to 0
Step 6. Reboot then Open Corsair Link 2 then Your Done.. Thanks for Watching"
Credit goes to "Dark Catharsis" on YouTube.
https://linustechtips.com/topic/265189-problem-with-h100i/#findComment-3620957
