I am building my rig and I wanted to know if I have to get a network card or does the motherboard also provides wireless networking because I wanted to go wireless, since no cable is reachable to my room because the router is in the living room and somewhat I don't have and router compatibility.
MB: MSI Z97-Gaming 5
https://linustechtips.com/topic/264868-do-i-need-a-network-card/
It looks like you need a network card, you can find some cheap ones for less than 20 to fit in a pci e 1x slot though.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/264868-do-i-need-a-network-card/#findComment-3601531
Can I suggest some plz, or at least what should I look for ?
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704129&cm_re=pci_e_wireless_card-_-33-704-129-_-Product
This is the one I personally have. Hasn't failed me and I have had it for over a year. Not that I use it much anymore, currently on wired.
https://linustechtips.com/topic/264868-do-i-need-a-network-card/#findComment-3601547
I am doing gaming btw
Get the cheapest wireless ac card that uses the pci interface. I'd go with the Intel 7260HMWDTX1.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/264868-do-i-need-a-network-card/#findComment-3601569
CPU: Intel Core i7-4790k @ 4.7 1.3v  with a Corsair H80 w/Dual SP120s - Motherboard: MSI Z97 gaming 5 - RAM: 4x4 G.Skill Ripjaws X @ 1600 - GPU: Dual PowerColour R9 290- SSD: Samsung NVME SM951 256GB-- PSU: Corsair RM 1000  - Case: NZXT H440 Black/red - Keyboard: Coolermaster CM storm Quickfire TK, Cherry MX blues - Mouse: Logitech G502 - Heaphones: Beyerdynamic DT 770 - Monitors: 3x VE248H Eyefinity 1080P -  Phone: iPhone 6S Plus               Please post your specifications in your post, signature or even better, system page on your profile!
https://linustechtips.com/topic/264868-do-i-need-a-network-card/#findComment-3601573
Can you suggest some plz, or at least what should I look for ?
I have a Gigabyte one with a black PCB. It works rather nicely. Model number is GC-WB867D-I.
Than if you can consider wired connection as you will have lag with wifi.
No you won't. I do it just fine, and my ping maxes out around 23ms in less than optimal conditions.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/264868-do-i-need-a-network-card/#findComment-3601576
Does the powerline adapter use the same internet plan I have in my living room or do I have to pay separate ?
i would think so since its just another medium to connect to the internet
Intel i7 4702MQ| Nvidia GTX 850M| Kingston 16GB DDR3 1600Mhz| Acer VA70_HW (mobo)| 1TB WD Blue| MATSHITA DVD-RAM UJ8E0|1600x900 display|Win 8.1
Intel i5 4690K @Stock| Sapphire 390 Nitro| Hyper X Fury 2x4GB| MSI SLI Krait z97| Noctua Nh-U12S | 850 EVO 256GB| 2TB WD Black | CM V 850w| Enthoo Luxe
If you want to tag me or any person with periods do: @[Member='Name]
https://linustechtips.com/topic/264868-do-i-need-a-network-card/#findComment-3601695
Yep, same connection as your home internet
You connect one end to the router using a short ethernet cable to the nearest plug socket, and put the other end near the PC, connect the cables up sync them and they work over your power lines.
https://linustechtips.com/topic/264868-do-i-need-a-network-card/#findComment-3601719
is this faster than wireless, can you suggest some under $50 the best ones
https://linustechtips.com/topic/264868-do-i-need-a-network-card/#findComment-3602331
