Could the mobo actually cause coil whine? I'm trying to figure out a coil whine problem even though its more like a buzz then a whine. I've RMA'd my graphics card twice ive checked my fans, and I now have a new PSU that I haven't tried yet I thought it was the PSU because I only have a corsair 430w with an athlon x4 760k and an Asus r9 270x. Asus says the minimum is 500w so i thought it might be that. My card buzzes when under load such as playing a game. It also buzzes when I'm in the bios settings, After about 10 seconds this thing just goes nuts and its driving me crazy.
https://linustechtips.com/topic/263986-mobo-causing-coil-whine/
Have you tried taking out certain pieces then booting up and see if you can pin point the problem ?
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/263986-mobo-causing-coil-whine/#findComment-3590443
I can hear its coming from my graphics card but that's obviously not the problem what else could I take out to try?
I just don't get why I'll have buzzing in the bios but not when I'm in windows unless I'm playing a game
https://linustechtips.com/topic/263986-mobo-causing-coil-whine/#findComment-3590465
