Do I need a speed controller?
Go to solution Solved by Excon,
Oh wow, Performance PCs  has the variable one for 75$, are they a pretty reputable site? I've never ordered with them before.
Yes, it is one of the most reputable if not the most. Definitely go for that
MCP655TM (with speed pump) $108 vs MCP655-B (locked at speed 4) $85.
Is it worth 30+ dollars? Also to get the speed version I will have to pay shipping, the non speed version is free.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/262910-do-i-need-a-speed-controller/
It is definitely worth it
Ugh.......smh......this is gonna cost me 130+ compared to 85 just for speed controller.......honestly debating if $50 is worth for speed controller...
Maybe look elsewhere? Not sure if youre in the US but look at PerformancePCs and FrozenCPU. You really only need to run the pump at speed 1 and while bleeding your loop flicking the pump from 1-5 quickly can help get stuck bubbles unstuck.
