Hi I'm building a PC that will be more portable than my last. Thanks for anyone who looks at this. Suggestions are most welcome. This is my second build ever, first on the Intel platform. My first was a complete and build. I decided to give Intel and nvidia a go because of performance issues on some of my favorite games. These are going to be the specs
Intel Core i5 4690k
Asus ROG MAXIMUS VII IMPACT
16gb Corsair Vengeance Pro 1866mhz CL9
Crucial M4 SSD and WD 1TB BLUE 7200rpm
Corsair RM650 power supply
Corsair h55 water cooling system
Noctua fans
Corsair graphite 340T black
Asus GTX 660 2gb gddr5
thanks for looking... Any suggestions are welcome
https://linustechtips.com/topic/261624-lan-party-style-build/
I would go with http://www.newegg.com/Product/Product.aspx?Item=N82E16814125706&cm_re=GTX970-_-14-125-706-_-Product
for the Graphics card
And i think you meant the Corsair 380T
other then that It looks ok
or wait for this one
http://www.techpowerup.com/207609/asus-readies-geforce-gtx-970-directcu-mini.html
https://linustechtips.com/topic/261624-lan-party-style-build/#findComment-3562973
@JoeKer please remember to follow your posts.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/261624-lan-party-style-build/#findComment-3563065
Intel Core i5 4690k
Noctua fans
Hey JoeKer,
If you are using this build purely for gaming, you probably wouldn't need that much memory. 2x4GB would be perfectly fine. Also, when it comes to gaming, your highest priority should be the GPU. If your budget is limited, I would suggest not overclocking that i5 (stock would be more than enough for gaming) and drop to a non-k version, omit the CPU Cooler and drop to a H97 motherboard. This would allow you to put more funds towards the GPU.
PSU-wise, you would be perfectly fine with a 500W gold-certified power supply as Intel builds tend to be very energy-efficient.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/261624-lan-party-style-build/#findComment-3563252
