Hi guys
Im looking to get a small case for my micro atx mobo. Im also getting a gtx760 and i want to incorporate a side fan into the build. Anyone know of a case into which these components will fit?
Thanks
Hey there, welcome to the forum!
Your choices would totally depend on your location, and how much you're looking to spend for a case. So you'll need to provide us with that info first.
"Rawr XD"
https://linustechtips.com/topic/260920-gtx760-side-fan/#findComment-3555762
Right. I live in europe, portugal. For the speed of delivery id rather buy from inside my country. As for the price, i intend to buy as cheap as possible in order to spend on other components. But im still looking for a sleek minimalist look. Something along the lines of NOX FORTE (which is cheap & kind of minimal look). Also, i need usb3 frontal connection.
Can i roughly calculate the extra for a fan by making a few calculation based on widths? Isn't there an easier way?
https://linustechtips.com/topic/260920-gtx760-side-fan/#findComment-3556179
