Is this a good first build?
http://pcpartpicker.com/p/9cFXFT
CPU: Intel Pentium G3258/MOBO: MSI H81M-E33/GPU: Sapphire Dual-X R9 270x/RAM: Team Dark Series 8GB DDR3-1600mhz/HDD: WD Caviar Blue 1TB/Case: Corsair Spec-01/PSU: EVGA 500B 80-plus bronze 500 Watts/OS: Windows 8.1 64-bit
https://linustechtips.com/topic/260502-first-build/
Switch the 260X out for this.
http://pcpartpicker.com/part/powercolor-video-card-axr92803gbd5t2dheoc
Als, that gold rated power supply... Switch it out for a modest Bronze one to save some dough.
Other than that, lookin good.
| Intel i7 5820K @ 4.8GHz | G.Skill Ripjaws 4X4GB | X99 PRO | HoF 980 | Asus MX299Q | Sennheiser HD600 |
https://linustechtips.com/topic/260502-first-build/#findComment-3550977
 if you cant afford the r9 280, a r9 270 is still going to better than the r7 260x and around the same price as it
Runescape player  II  Civ 6 and LoL noob  II
https://linustechtips.com/topic/260502-first-build/#findComment-3550999
Ive heard a little of both sides about powercolor so would it be a worthy buy? Also, the gold rated psu is on sale for just as much as the bronze cx 430, and is semi modular. Thanks for the feedback!
https://linustechtips.com/topic/260502-first-build/#findComment-3551001
Powercolor is a fine vendor. If you cant afford it right now, just save up a tad more, and then jump at it. The performance difference is huge when compared to the 260X.
https://linustechtips.com/topic/260502-first-build/#findComment-3551022
Is the 750 ti better than the 270?
https://linustechtips.com/topic/260502-first-build/#findComment-3551023
