about twice as much as 970's.  :lol: according to guru3d one 290 is 250w~.
https://linustechtips.com/topic/260413-wattage-for-two-290s/#findComment-3549931
Psu should be an 850w for any kind of oc headroom.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/260413-wattage-for-two-290s/#findComment-3549939
Gonna be allot of heat.....
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/260413-wattage-for-two-290s/#findComment-3550011
That's nowhere near twice the power consumption of a 970. 970 at stock clocks ~ 160W, R9 290 with a slight OC ~250W.
OP, ~500W for the R9 290s. With factory overclocked 970s you are usually pretty close to 180W or even 200W per card, so ~350W minimum for SLI 970s. After that you have to factor in everything else though, a modern 4-core intel CPU will stay below 100W even with a moderate OC, then there's mobo + fans + HDDs + ram, which isn't that significant but can add up with certain setups.
https://linustechtips.com/topic/260413-wattage-for-two-290s/#findComment-3550063
