Please dont suggest things that arent on this site or tell me to import stuff!
This is the only company in my country that i have found that supplies Custom loop stuff
I have a H440 case so a Bay pump and res wont work.
I plan on doing my CPU first then adding a GPU to the loop later.
What would be the best from the site:
http://titan-ice.co.za/cooling-liquid/pumps-reservoirs-combos/
Pump?
Res?
or
Pump/res combo?
I was going to go for the XSPC X2O 450 Pump with Acrylic Reservoir with a 240mm Radiator then add another 240mm radiator when i get a GPU block.
And then what should i ask them to see if they can get from XSPC and Alphacool as those the only 2 good brands i see they supply.
Only recommend a pump, a res or a pump res combo for the H440 and nothing thats brand new because i know they wont be able to get it.
GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 @1500mhz + 8000Mhz CPU: Intel Core i7 6700k Delided and Overclocked @4.8  MB: ASUS MAXIMUS VIII IMPACT  RAM: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory CPU Cooler: Corsair HG10+ H90 +H90 CASE: Corsair 380T  Storage: 120GB Samsung Evo SSD + Crucail 256GB Mx100 + 2TB Seagate/  OS: Windows 10 64bit Power supply:  Corsair RM750
https://linustechtips.com/topic/260370-what-pump-res/
