Hello!
I installed crystaldiskinfo to check it out and i noticed that i have written 1.99TB on my samsung 830 120GB ssd! I know SSDs have a maximum write limit. I want to know how much longer will my SSD last before i have to replace it. Is ~2TB of writes much? I also disabled the fast boot option of windows 8 ( I didn't needed it anyways) because i found out it was writing big amount of data every time i shut down my laptop. Also I would like to know if there are any tweaks i can make to reduce writes. Thanks!
AMD FX 8320@ Stock - Asus M5A99X Evo R2.0 - Kingston HyperX 8GB 1600Mhz - Corsair Carbide 200R - Powercolor Radeon HD 7950 PCS+OC@970Mhz core 1400Mhz memory - Corsair CS650W - Samsung 840 EVO 250GB
LG 22EA53VQ 21.5" - CM Storm Xornet - CM Storm Quickfire TK - Creative Inspire T3130 2.1
https://linustechtips.com/topic/25658-ssd-writes-problem/
Taking your total writes and dividing by your power on time gives roughly 25GB of writes per day.
You'll be fine, even with that many writes your SSD will probably last 10+ years, and I'd be surprised if anyone used the same SSD for that long. :P
(Making my estimations based on this article: http://www.anandtech.com/show/6459/samsung-ssd-840-testing-the-endurance-of-tlc-nand)
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/25658-ssd-writes-problem/#findComment-326081
I sure wont keep this SSD for more than 10 years but I want to be safe. Thank you!
https://linustechtips.com/topic/25658-ssd-writes-problem/#findComment-326105
