I have a Msi z87-g45 mobo and was thinking about getting a Pentium g3258 so I could overclock it but I read that some people needed to update the bios to overclock, and I really don't want to go through the trouble of updating the bios so I was wondering if anyone knows if I can overclock without updating bios. If I have to update the bios I will probably get an I5-4670k. Any help is appreciated
https://linustechtips.com/topic/255963-need-cpu-help/
Ya the only reason I want the Pentium over an i5 is because I never really overclocked a cpu before and I wanted to mess around with it
you will probably need to updated the bios whatever cpu you get. you can overclock an i5 just as easy as a Pentium as long as you get a decent cooler.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/255963-need-cpu-help/#findComment-3503868
