How much exactly are you willing to spend?
CPU: AMD Ryzen 7 3800X GPU: ASUS Strix Radeon R7 5700 XT OC Edition Motherboard: ASUS Crosshair VIII Hero RAM: G.Skill Trident Z DDR4-3200 CL14 SSD: 2x Samsung 970 EVO Plus 1TB PSU: Corsair AX860 Cooling: NZXT Kraken X72 Case: Corsair Crystal Series 570X Mirror Black Display: BenQ XL2420Z  Keyboard: Corsair K95 RGB Cherry MX Blue Mouse: Logitech G502 Proteus Spectrum Audio: Logitech G633 Artemis Spectrum
http://pcpartpicker.com/p/2QKvNG
I think this bulid is a little bit better than yours. With 2k, you could upgrade your air cooler from a 212 evo to a nh-d14. I also added in a 970 and a 256gb ssd. Lastly, i changed out the power supply to a better one for the price. It's cheaper, and performs and looks better, imo. Hope this helps!
^ His build is what you would want to consider
I see what you mean for the ssd and the power supply and the cooler but really that graphics card is all that really helps although 2k is my budget I would still like a little left over
Then why that keyboard and the mouse? Why not get corsair k70 RGB and Logitech g502?
I play alot of media and programing so the das keyboard is the best for that and I rest my hand on my mouse for long periods of time so I want something that is nice and wide to fit my hand
I also like the brown switches and basic colors
