Can Someone help me
Solved by Sharp_3yE,
i dont think it had anything to deal with a debugging issue if that helps
First off, you can press EDIT on here to just add more to your last post.
So, it sounds like you have IE as your default browser. To set a program as default simply go to Control Panel\Programs\Default Programs\Set Default Programs but you can also type in "default programs" in the search bar and press enter or click the option. Go to Firefox, click on it, then click "set this program as default"
You can do this with any type of program. If you want a certain music player to be your default music player then find that program in that selection and made it your default. If you have windows 8.1 you probably want to change the default photo app as well.
