Help Choose A SSD
Go to solution Solved by officiallyasimulator,
Hyper 3k, the MX100 is also a good idea. if not the evo is a good choice.
CPU Intel I7-4700MQ @2.4 ghz, turbos to 3.4
Motherboard  whatever toshiba put in the thing
RAM 8GB 1600mhz
GPU  Nvidia Geforce GT 740M
Storage 750Gb 5400rpm
Cooling  Crappy laptop fan
Operating System  windows 8 64 bit
01101001 01100110 00100000 01111001 01101111 01110101 00100000 01101000 01100001 01100100 00100000 01110100 01101111 00100000 01000111 01101111 01101111 01100111 01101100 01100101 00100000 01110100 01101000 01101001 01110011 00100000 01101001 00100000 01100100 01101111 01101110 00100111 01110100 00100000 01100010 01101100 01100001 01101101 01100101 00100000 01111001 01101111 01110101
https://linustechtips.com/topic/251037-help-choose-a-ssd/#findComment-3441508
How about the MX550
is pretty good, ive heard great things about the mx100 though
RAM 8GB 1600mhz
https://linustechtips.com/topic/251037-help-choose-a-ssd/#findComment-3441541
