Hello.
I have a windows 8 desktop of HP and it has a GTX 660 I put inside.
I was recording and playing tf 2 with my friend and then suddenly my computer flipped out and I have shut down and the GPU sopped working until I fixed it. Everything is working BUT the keyboard and mouse aren't. My mouse laser is lit up but not my keyboard and I can't move the cursor nor I cannot log in. Keyboard works through BIOS but not at log in screen.
Any solutions?
https://linustechtips.com/topic/248533-keyboard-and-mouse-problem/
Check which port you have them connected in. If they're in a USB 3 port, maybe something happened to the driver, and you have to reinstall it.
USB 3 on my motherboard doesn't work untill I install the driver-
There should be 1 or 2 USB 2 ports (usually black, not blue), or you could try the P/S2 port if you have one, and have an adapter.
Sorry for the few off Capital letters in my posts, it does it on its own when I Write in English, since my OS is in another Language. It's annoying.
