Imo I would suggest more ram, like 16gb, and getting an SSD for faster performance. Also your PSU is a bit overkill, unless you are planning for extra cards in the future
Desktop: i7-4790k, Samsung 840 EVO 250GB, Seagate Barracuda 3TB, 2xR9 290 Vapor-X's (1 working atm), Asus Z97-Pro, NZXT H440 White, 16GB G. Skill Sniper RAM, NZXT HALE V90 850W.
Laptop: Samsung Chromebook 11.6"
Phone: 8GB Galaxy S4
https://linustechtips.com/topic/243294-build-sound-ok/#findComment-3332434
AMD FX-6300 3.5GHz 6-Core Processor](http://uk.pcpartpicker.com/part/amd-cpu-fd6300wmhkbox) | £72.99
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler](http://uk.pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2) | £23.82
Asus M5A97 EVO R2.0 ATX AM3+ Motherboard](http://uk.pcpartpicker.com/part/asus-motherboard-m5a97evor20) | £68.98 @ Amazon UK
Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory](http://uk.pcpartpicker.com/part/corsair-memory-cmz8gx3m2a1600c9b) | £63.25
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive](http://uk.pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex) | £39.99
Gigabyte Radeon R9 280 3GB WINDFORCE Video Card](http://uk.pcpartpicker.com/part/gigabyte-video-card-gvr928wf3oc3gd) | £152.72
Corsair 200R ATX Mid Tower Case](http://uk.pcpartpicker.com/part/corsair-case-200r) | £43.48
Corsair CSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply](http://uk.pcpartpicker.com/part/corsair-power-supply-cs550m) | £55.99
Lite-On iHAS124-14 DVD/CD Writer](http://uk.pcpartpicker.com/part/lite-on-optical-drive-ihas12414) | £11.16
Microsoft Windows 8.1 (OEM) (64-bit)](http://uk.pcpartpicker.com/part/microsoft-os-wn700615) | £71.99
    **Total**
 Prices include shipping, taxes, and discounts when available | £604.37
I've changed your PSU and added an Hyper 212evo CPU coller.
https://linustechtips.com/topic/243294-build-sound-ok/#findComment-3332435
Yes as I plan on using it alot and the trial using has lots of annoying bugs
*sigh*
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor  (£152.23 @ Scan.co.uk)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  (£30.97 @ Scan.co.uk)
Memory: Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600 Memory  (£57.99 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£39.99 @ Amazon UK)
Video Card: XFX Radeon R9 280 3GB Black Edition Double Dissipation Video Card  (£149.14 @ Scan.co.uk)
Case: Cooler Master N200 MicroATX Mid Tower Case  (£32.04 @ Scan.co.uk)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£55.20 @ Kustom PCs)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer  (£13.15 @ Amazon UK)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  (£72.97 @ Scan.co.uk)
Total: £603.68
Steve
https://linustechtips.com/topic/243294-build-sound-ok/#findComment-3332516
I was thinking of upgrading my Gpu later on so thats why I have went for a bigger psu and it has a 5 year warranty with it and do I need a cpu cooler as I was not totally planning on OC but it would be nice for the pc to be quiet
If you want to upgrade why would you go with a 280 then? It is good enough to last a couple years. You would only need more if you will run 2 way
https://linustechtips.com/topic/243294-build-sound-ok/#findComment-3332566
I was considering the xfx model but the gigabytes benchmarks looked better and will the msi motherboard last long?? I am aiming for the pc to last for around 4-5 years with some upgrades until I go to uni then ill do a complete revamp of it.
you can overclock the xfx to match the gigabyte and you can upgrade the motherboard when you feel like it with the case
Steve
https://linustechtips.com/topic/243294-build-sound-ok/#findComment-3332755
