Currently i only have 1 PC, so i can't really do tests, but i wanna find out the solution before i even buy anything.
My idea is making a small PC with an AverMedia Live Gamer HD as capture card.
I then wanna clone my screen from my monitor, to the capture card to get the video without losing my 120hz refresh rate (as explained here: https://obsproject.com/forum/threads/dual-pc-setup-120hz.8678/#post-49170 ).
But how do i go about getting mic and audio to the capture card?
My current PC got a SoundBlaster Z soundcard, where i can stereo mix to the digital out on the card, though the capture card doesn't support that.
I also got my onboard sound, SoundBlaster Cinema 2 (i do not plan on using onboard audio unless necessary)
https://linustechtips.com/topic/240535-cloning-audio/
