Hello,
I got a new router, the Linksys WRT1900AC.
Well, I've got a problem with it, it doesn't have any DNS or something.
Every time I try to connect with f.e. a tablet, it has a DNS error.
Since I had this on my laptop, I tried using the Google DNS on my Ethernet connection and it worked.
But this is pretty annoying, always having to set up a DNS on every device.
I have everything set up on the router like my previous one but it isn't working.
Anyways, can someone explain why this is happening and a guide how to fix it?
My parents are pretty mad because almost no device has internet.
Thanks
I was going to put my image signature here, but the forum said I couldn't.
https://linustechtips.com/topic/239844-dns-problems-with-wrt1900ac/
I would suggest looking through the router settings and trying to find the one regarding DNS servers, then set it to use Google's servers (or whichever you like).
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
Go under the connectivity tab in the Linksys firmware then to Local Network and set a static DNS to OpenDNS, the servers are 208.67.222.222/208.67.222.220 also use the second server for the third static DNS as well.
Mein Führer... I CAN WALK !!
