Home ethernet connection
Go to solution Solved by JohnnyGrey,
You can't connect a computer to a phone plug. Just won't work. You either have to swap out connectors or go without Ethernet.
I have my house wired for rj45 connections, and they come out as rj11? (I think thats the term) how do I connect my router to the houses Ethernet connections, I know ill have to switch the rj11 to 45's but I dont know how the house connects to the router...
sorry if vauge i hardly know what im talking about, but i want my pc connected via Ethernet from 2 stories up
Current Build: Desk
My case is my most expensive part
Its Almost 2015 and I don't have an SSD
https://linustechtips.com/topic/239454-home-ethernet-connection/
So, the phone line that comes into your house is RJ-11 and your PC is RJ-45? You will need a modem.
Or are you saying that the wall plates are RJ-11? Because those aren't ethernet.
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283520
The plates coming out of the wall are rj-11 but i need them to be rj-45, then i need to cocennect the house wiring to the router, which is rj-45 but i don't know where the heck to connect it at
Current Build: Desk
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283541
If you only have RJ-11 you're not going to be getting it to RJ-45 without ripping some walls open and gutting thr cables.
There is a big difference between RJ-11 and RJ-45... namely there are fewer wires and you're not going to get decent speed on it, either.
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283621
You won't be able to convert your RJ-11 phone lines to ethernet, so your only option is to route new ethernet through your house. This can be a difficult task, so you might have to cut walls open, drill holes, and might require going into your crawl space/attic.
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283716
I think the wiring is rj-45 but is a female rj-11 jack? I know that the house is wired for eithernet but the only line that fits in the wall is a phone line
Current Build: Desk
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283783
If you're wiring your house using ethernet cable, just replace the wall jack to RJ-45, but it's confusing how do you connect 8 cable ethernet to 4 pin RJ-11 in your house installation? If you only use 4 cable (pair green & orange) and connect it with RJ-11 female wall jack, just convert that pair to standard RJ-45. With 4 cable you can still have 100Mbps ethernet bandwidth.
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283808
You need to take off one of the wallplates, and see how many wires there are. If it's infact Cat5 cabling, you'll probably see four wires going to the RJ11 jack, and four taped off, or two going to the jack, and 6 taped off.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283828
Is it possivble to get pictures of the router, input socket and output socket (At the router and the room you want it in?)
This might clear things up.
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283835
If you pull off your wall plate you could check to see if Cat5/5e/6 cable was used as phone line, but I highly doubt it. If it is ethernet, then you will need to go to your phone line termination box and remove the cables you want to use, then re route those either to or near your router. Then you will just replace the keysones with RJ-45 ones(You will want to buy a keystone punch tool).
Easy, you only use 4(or 2?) of the 8 wires. I've seen people use ethernet as phone line and they just cut the wires they don't need.
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283842
^ Truth. The townhome I'm renting a basement in from some friends has the place wired with Cat5e cabling, but where they converge is a shitty job. (Right above my desk, in fact, by the electrical box.)
Gaming PC
  • Storage:
  • W11Pro
Media Server
  • Unraid 6.9.2
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283857
Some non experienced technicians didn't know the standard of ethernet cabling. There is time when I'm fixing ethernet link in a dormitory and it turns to be a frustrating work because all the cables on the switch are not labeled and the ethernet cabling order was not right at all.
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283896
okay, ill check in a sec here, how would i connect the router to the houses Ethernet then?
EDIT: It is rj-45 wiring, so ill change the connector to a rj45 then now i just need to connect it to the router...anyone?
Current Build: Desk
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283954
You have to find where all the wiring comes together. I'm guessing somewhere in the basement. You can't just have a bunch of Cat5 cabling going to a bunch of wallplates all taped together. You'd have to cut off all the ends where the wiring comes together, put RJ45 connectors on, and then have the router there.
Gaming PC
  • Storage:
  • W11Pro
Media Server
  • Unraid 6.9.2
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3283980
okay, so id be fine using a rj11 to rj45 wire to connect to my pc? and then there two wires that are connected into the router already, i think the router is in the same room where the cables meet and the two are going to a couple different ports, if i get a rj11 to rj45 cable would i have internet?
To conclude:
I think the router is connected to house cat5 cables
The cabling is cat5 to rj11 port, but my dad wont let me change it to an rj45 connector
Hopefully this works?
Current Build: Desk
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3284108
Gaming PC
  • Storage:
  • W11Pro
Media Server
  • Unraid 6.9.2
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3284211
well thats a bummer :( thanks for the help, if my dad ever changes his mind, ill know what to do!
Current Build: Desk
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3284230
To conclude:
Assuming the RJ-11 connected to pair green & orange, just make a ethernet cable using RJ-11 on one side and RJ-45 on the other side with pair green & orange connected to pin 1,2,3 & 6. Check on google for ethernet wiring diagram.
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3286900
Most people here are wrong!>.< using your phone lines for internet connectivity is easy!
Step 1: establish the kind or cable yo have running in your walls. Most houses come with either CAT3, CAT5, and CAT5e.
             You might see CAT6, but that is only in large new houses. The main diffrence between the cables is the amount of twists the
              pairs have.CAT5, Cat5e, and CAT6 cables will all work. unfortunately, CAT3 wont do you any good.
Step 2: Terminate wall jack. you might have to go out and buy a new wall plate and a connector block. this vidoe can show you how to do it!
Step 3: You will need yo figure out exactly where the other end of the cable is going to/from. Normally, network cables are routed to one of 3
             ways. Most commonly, they go to a central hub located outside the house. if so, you will need to take the cable from outside your
             house and you will have to re-route the cable to the room with your router. Cables can also be ran to a central box inside your house
             usually inside the closet known as smart pannels. Most smart panels come router ready, they may contain a power outlet and
             ventilation holes for you to put a router in there(this is the best way to have your house wired). Or you may have a daisy chain. This
             is when you take just one cable ran throughout your whole house and just spliced where your phones go. You will not be able to do
              much with this setup.
Step 4: Connect! you will need to connect a router to one end of the cable, get the other end of the cable and you can now connect a
             computer or another network device to your wall.
NOTES* basically, your goal is to have one good connection from point A to point B. I recommend you test the connection at every point. test your connection from your modem, then from modem to router , from router to wall, from wall to other wall, from other wall to computer. (if that makes any scene at all >.<) These are just basics and every house is different. So this may be of no good use for you. But if you have any questions feel free to ask me, I do this for a living so i may be able to help!
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3289860
I agree with everything said! Let's hope the residence is new enough to actually have modern wiring in the walls. My mom's house is from either the 70's or 80's, and is a cheap pre-fabricated house, so all it contains is old solid copper single pair phone cable. Now that's a pain!
I was merely stating before that an RJ11 plug itself can't be used for computer connectivity, since the OP's dad won't let him change to RJ45 Jacks/plugs. The wiring behind the plate may very well be perfect for home ethernet wiring. It'd just a matter of find how and where all the connections converge inside the house.
Gaming PC
  • Storage:
  • W11Pro
Media Server
  • Unraid 6.9.2
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/239454-home-ethernet-connection/#findComment-3290179
