I'm trying to overclock my two 280x's but am having issues with changing the voltage. I am using MSI Afterburner, when i change the voltage and apply i run unigine heaven the voltage doesn't change at all from what it used to run at (1.2v for the VTX3D and 1.21v for the XFX card). I set it to 1.25v. Verified in both Afterburner and GPU-Z.
Are they voltage locked or am i missing something?
GPU 1: VTX3D AMD Radeon R9 280x
GPU 2: XFX AMD Radeon R9 280x DD Black
Case: Phanteks Enthoo Pro | PSU: Enermax Revolution87+ 850W | Motherboard: MSI Z97 MPOWER MAX AC | GPU 1: MSI R9 290X Lightning | CPU: Intel Core i7 4790k | SSD: Samsung SM951 128GB M.2 | HDDs: 2x 3TB WD Black (RAID1) | CPU Cooler: Silverstone Heligon HE01 | RAM: 4 x 4GB Team Group 1600Mhz
https://linustechtips.com/topic/238879-voltage-issue-with-280xs/
Apparently the XFX 7970 is voltage locked... wouldn't be surprised if the 280X (same GPU) is as well. Not sure about the VTX.
http://www.reddit.com/r/hardware/comments/yxkkg/xfx_has_voltage_locked_their_lineup_of_7970_dd/
"Rawr XD"
https://linustechtips.com/topic/238879-voltage-issue-with-280xs/#findComment-3276377
Would flashing it to a different bios help? The VTX3D card uses Samsung memory which very few bios' seem to support. There is one MSI one that does. Are MSI bios' generally unlocked?
https://linustechtips.com/topic/238879-voltage-issue-with-280xs/#findComment-3276398
