Hi internet land
Pc specs:
mobo: Asus ranger VII
cpu: I-5 4690 oc-4.1Ghz
gpu: R9 290 oc- 1140Mhz
8 gig ram
samsung SSD boot drive
Cpu/Gpu custom water-cooled loop with a single 280x60mm radiator ( planning on installing a second of the rad soon once i've build the case for it)
when i leave my pc to idle and eventually going into sleep mode (monitors turning off whilst the tower stays active) the temps on my Gpu climb to 50-55 degrees
(normal idle about 27-33 degrees), I normally see 50-55 degrees when it's under heavy gaming load.
 Hopefully someone is able give me some insight whats going on?
https://linustechtips.com/topic/238683-strange-temps-question/
