Cooling for AMD FX-4170
Go to solution Solved by Stav Kats,
Option 1.
Option 2.(better performance than a H80)
Hey. I thinking of buying either water cooling or a New fan to cool my AMD FX-4170. Problem is the Tower im using is not built for all types of cooling systems (http://www.dustinhome.no/product/5010335510/cooler-master-miditower-elite-310-atx-black-orange/). So what kind of cooling would you guys recommend for me to keep my cpu temp down, but in a silent way. Watercooling would be Nice if that is possible :)
https://linustechtips.com/topic/23862-cooling-for-amd-fx-4170/
Option 1.
CPU: AMD FX-6100 Black Edition @3.9GHz GPU: XFX 7970 DD (1062/1520 MHz) MOBO: ASUS Sabertooth 990FXA(1st Revision) RAM: Corsair Vengeance 16GB @ 1333MHz Storage: Corsair Force 3 120GB(Boot) + WD Green 1TB(storage) PSU: FSP AURUM 600W(80+ Gold) CPU Cooler: Cryorig M9a  Case: NZXT Tempst 410 Elite(Mid-Tower) Mouse: Logitech G602(Manufacturer Refurbished) Keyboard: Noppoo Choc Mini(Cherry MX Blue) AUDIO:Sennheiser HD 598+ASUS Xonar DGX Monitor: LG M2280DF 21.5" 1080p(TN-75Hz)
https://linustechtips.com/topic/23862-cooling-for-amd-fx-4170/#findComment-302391
Option 1.
That is a very nice cooler. Btw have you got any knowledge about NZXT coolers, they look nice but it is about looks thats it or is there something above that.
Listen if you care.
https://linustechtips.com/topic/23862-cooling-for-amd-fx-4170/#findComment-303040
As far as Air Cooling goes, I would recommend the Havik 140, great cooler.
As far as Liquid Cooling goes, Kraken x60 is one of the top cpu coolers and x40 is not bad at all.
https://linustechtips.com/topic/23862-cooling-for-amd-fx-4170/#findComment-303080
for such a low end cpu a cooler master hyper 212  plus oir evo would do the job. Its cheap and very effective. i got mine for like 20 bucks. 30 right now. http://forums.ncix.com/forums/?mode=showthread&msg_id=2585461&threadid=2585461&forum=100&product_id=64385&msgcount=7&overclockid=0#msg2585461
Amd fx-8320 oc 4.1ghz, 8gb ram, gtx 780ti 3gb, 240gb ssd, 1.5tb hdd,
https://linustechtips.com/topic/23862-cooling-for-amd-fx-4170/#findComment-306086
