So for about the past 2 months I've been experiencing problems with my system completely locking up when something is inserted into the USB port. I have tried everything but can't find a solution.
...But it isn't all of the time and sometimes it just locks up on boot. Its mainly when something is plugged into any of the USB ports though. It occurs on every port be it back ports or case ports.
I'm running a 2500k at stock speed on a Gigabyte Z68X-UD3H-B3, H100i, 16gb HyperX Predator, Samsung Evo 840, GTX 760 if this is useful to anyone.
I'm drawing a blank and can't really find anything online but as I am a stop motion animator, I am constantly plugging my camera into USB so it can be quite a frustrating process.
https://linustechtips.com/topic/238442-complete-system-lock-up-when-usb-is-inserted/
sounds like the wundows updater maybe causing it ?? just an idea
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
The first thing I'd suggest is to see if there's a motherboard update.
Second is to update all the intel chipset drivers (http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/20775/eng/SetupChipset.exe&Lang=eng&Dwnldid=20775)
