I currently have a cooler master JetFlo fan which brings air into the case from the front. However, that fan seems to be struggling to move any air at all and i believe it may be to do with it being in a confined space and have to push air through the front of the case and the hard drive bays.
Now my question is; Would it be better having a high static-pressure fan instead of the JetFlo? I'm looking at the Noctua NF-F12 PPC 3000RPM PWM fan, would that be a better option? I'm open to other fan suggestions.
Thanks.
Case: Phanteks Enthoo Pro | PSU: Enermax Revolution87+ 850W | Motherboard: MSI Z97 MPOWER MAX AC | GPU 1: MSI R9 290X Lightning | CPU: Intel Core i7 4790k | SSD: Samsung SM951 128GB M.2 | HDDs: 2x 3TB WD Black (RAID1) | CPU Cooler: Silverstone Heligon HE01 | RAM: 4 x 4GB Team Group 1600Mhz
https://linustechtips.com/topic/236763-better-intake-fan/
Yes is a better option but it won't make much of a difference in temp.Hdd can work at high temps for very very long about the general temp...well idk maybe 5 degrees if the air is cold
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/236763-better-intake-fan/#findComment-3246133
JetFlow is a high SP fan. Looking at pictures of your case makes me think it's just the fact that your hard drive cage is very restrictive. Static pressure can't compensate for bad case design. But the fresh air will get where it's needed, just not efficiently.
I'd recommend a new case before expensive fans.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/236763-better-intake-fan/#findComment-3246142
I would upgrade the case however money at the moment is very tight and i couldn't afford a new one right now. So just trying to find a way of making the airflow a little better until i can afford a new case, which probably won't be for a few months.
https://linustechtips.com/topic/236763-better-intake-fan/#findComment-3246224
You need high static Pressure fans i would suggest scythe Grand flex 2400 PWM with has 4.5 static pressure and around 100 cfm thus you get both airflow and static pressure http://www.scytheus.com/product/grand-flex-pwm/ and it is cheaper than Corsair fans
Grant us the joy of song and dance and ever watch over us in the lonely places in which we must walk - Pray to Bastet
https://linustechtips.com/topic/236763-better-intake-fan/#findComment-3247071
