I need help to build my first gaming pc for around 900 dollars. If it's possible i want to play games like Far Cry 4 (when it's gonna come out) ultra settings with no lag.
You might what to ask in the new builds and planning part in the workbench section of the forums, you will get more help there then in the PC section.
Cry Havoc!
https://linustechtips.com/topic/235656-can-i-get-help/#findComment-3229059
http://pcpartpicker.com/p/Jt2NBm
Maybe not ultra, but close.
I could be very wrong
https://linustechtips.com/topic/235656-can-i-get-help/#findComment-3229061
This is LTT. One cannot force "style over substance" values & agenda on people that actually aren't afraid to pop the lid off their electronic devices, which happens to be the most common denominator of this community. Rather than take shots at this community in every post, why not seek out like-minded individuals elsewhere?
https://linustechtips.com/topic/235656-can-i-get-help/#findComment-3230409
G2A is good as well for getting a OS
https://www.g2a.com/windows-8-professional-32-64-bit-cd-key-global.html
I think I get my Win 8.1 for maybe $18
Its a lot now but it going up and down. You will just need a boot disk or some thing.
https://linustechtips.com/topic/235656-can-i-get-help/#findComment-3231767
