I am planning on getting new tubing and fittings. With this i am stuck on whether the fittings and tubes that I am planning on buying will fit or not.
I will be using compression fittings from XSPC and the tubing from XSPC.
Could someone please tell me what the common size for tubing and fittings are. I would like to know the "unofficial" standard.
I have been quoted from a Perth computer store. I will provide a atach below and I would like to see if it works together. Taken PDF Down
https://linustechtips.com/topic/235426-will-this-cooling-loop-fit-together/
Yeah its all good. Please take down that PDF. Don't ever post personal details on the web............. It'll cause you all sorts of pain.........
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
