Hey guys! I am from Singapore and i need help on building a computer. I just need it for a lot of recording and editing as I'm more of a console gamer. I will also play games like MineCraft and Counter Strike casually. My budget for just the pc is around 1500 SGD excluding the keyboard and mouse. I will really appreciate your help. Thanks
Hash
https://linustechtips.com/topic/235405-help-on-building-a-pc/
CPU- Intel 4770k
CPU Cooler- Hyper 212
GPU- GTX 760 (even maybe a 770)
PSU- Corsair CS750M
Case- NZXT H440
Storage- 1x Samsung 120gb SSD 1x Seagate Barracuda 1TB
MB- MSI Z97 Gaming 3
Memory- G.Skills RipJaws 8GB
someone else may have another opinion though.
https://linustechtips.com/topic/235405-help-on-building-a-pc/#findComment-3225505
we need more information please read this and use the quote button if you want my help
http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
Specs
https://linustechtips.com/topic/235405-help-on-building-a-pc/#findComment-3225571
CPU- Intel 4770k
PSU- Corsair CS750M
Case- NZXT H440
120gb for Editing is far from enough, he will need atleast 500gb
Main PC/Gaming PC - G3258 @ 4.0GHz | Sapphire R9 280 3gb | 2x4GB Kingston Fury HyperX Blue 1600Mhz RAM | ASRock H97M Anniversary | x2 Seagate Barracuda 1tb | Coolermaster N400 Windowed | EVGA 600B 600W PSU | Windows 8
Keyboard, Mouse etc. - Razer Blackwidow Expert 2014 Green Switches | Logitech G502 Mouse | Logitech G430 Headset | Logitech C920 Webcam |
Screens - Acer K27HL | Acer S23HL | 32" Full HD TV (Don't know brand) |
https://linustechtips.com/topic/235405-help-on-building-a-pc/#findComment-3225635
Get this, has great performance for the price and is good for editing and stuff. Also has endless (sort off) upgrades
 http://pcpartpicker.com/p/4MnJNG
https://linustechtips.com/topic/235405-help-on-building-a-pc/#findComment-3225661
thats why i included the 1tb. for now the 1tb should be enough
Sorry, didn't see that, he can use the SSD for Boot drive and then the 1tb for the editing and shit
https://linustechtips.com/topic/235405-help-on-building-a-pc/#findComment-3225665
Total misappropriation of funds...
You can do so much better for the money for your given task.
You should be looking at X99 and a 5820K. The most GPU you could need for your tasks is a 750Ti.
Intel Inside. Overweight guy in his 30's outside.
https://linustechtips.com/topic/235405-help-on-building-a-pc/#findComment-3226596
I would have to disagree, although I would reccommend an i7 and a 770 or something like that
https://linustechtips.com/topic/235405-help-on-building-a-pc/#findComment-3227870
So could you guys recommend me a good build with the best parts available for my budget?
Praise be tomshardware!
Singapore
Fullwell
CH Computer <--- Geared toward overclockers
Chamoxa
The problem is we cannot do a build on pcpartpicker for you and hope it works. We'd have to essentially guess what the retailers would have in stock or if they even sell the parts we might recommend, and guess to the overall price of this supposed build. What I can do is give you a rough guide and tell you what you may be able to get for the budget and tell you to look for the parts. Once you find everything you want, make a pcpartpicker and show it to us. Then we can critique it as best as we can.
If the budget is 1500 Singapore Dollars, that's roughly 1200USD. I'd recommend a 4690k, Z97 ATX mobo with SLI support minimum 6 Sata3 ports. Choose a nice cooler like the Cooler Master Hyper 212. 8GB of DDR3 RAM should be ok. For storage, choose a 120gb SSD and a 1TB HDD. For the GPU, choose either a GTX 760 or 770, or R9 280, 280x or 285. For the case, see if you can find the Zalman Z3 Plus, Corsair 200r, Corsair SPEC, or something well made but inexpensive. For the Power Supply, choose something 750w for future SLI/Crossfire, fully or semi modular and from a reputable company. Find all of these on a Singapore site or more than one site, choose the ones you like then put them in a pcpartpicker list, then show them to us. Also tell us the total price it comes to. If you have a lot left over we can upgrade something like the GPU.
https://linustechtips.com/topic/235405-help-on-building-a-pc/#findComment-3257630
