So I'm having some trouble trying to get my old GTX 650 to perform. Running the new Borderlands on moderately high settings, I was noticing a lot of framerate dips, and could rarely stay above 50 FPS, especially when things got busy on screen. Since I'm broke as hell and am pretty much stuck with this GPU for a while, I figured I'd try to overclock it and get a bit more life out of it.
The stock speeds for the core and memory are 1202MHz and 1250MHz respectively. I did a bit of reading and found a handful of fairly common overclocks for this card (EVGA GTX 650), running the gamut from between +150/+165 to upwards of +200/+350. Tried them all at varying voltages with no success. I even attempted a more subdued overclock of +100/+120, and still experienced crashing.
Unigine Heaven gave me a rating of 542 stock, and couldn't complete the benchmark successfully on any of the above OCs.
Anybody got some tips or tricks that might get this thing working?
https://linustechtips.com/topic/235307-help-overclocking-gtx-650/
Haven gave me a rating of 542 stock, and couldn't complete the benchmark successfully on any of the above OCs.
With Kepler overclock by using a base of +13 for it on stock voltage.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
Seemed promising at first but it still wont push past 1305MHz without crashing. What I find confusing is that I managed to get it higher at first, and once I started scaling back down to what had been "stable" before, it was crashing at values it had previously completed no problem. Any ideas?
