When testing my Modmic 4.0. I need to set my microphone boost to 20 at 100% just for it to be loud enough, when doing so, there would be a lot of static noise. Currently I have it plugged into my motherboard. Do I need a USB to Audio soundcard or would just a usb to audio adapter be just fine?
You must "Quote" to get my attention​.
 ~IBIubbleTea - 20/07/2014
https://linustechtips.com/topic/235292-modmic-40-static-noise/
Hey, I was searching around and I found this.
http://www.amazon.com/Syba-SD-CM-UAUD-Adapter-C-Media-Chipset/dp/B001MSS6CS
When reading through some reviews. I found this
http://www.amazon.com/gp/review/R37Q7W5SRVY3QM/ref=cm_cr_pr_rvw_ttl?ASIN=B001MSS6CS
"Drawbacks?
The microphone input is mono, which is fine for voice headsets, but probably not great for pro audio recording, which probably wouldn't be done with a $10 device anyway."
What does he mean? Does this mean that when I record my microphone audio, it's going to come out on one side, ie left?
https://linustechtips.com/topic/235292-modmic-40-static-noise/#findComment-3223975
No, it means the L/R channel will be exactly the same.
https://linustechtips.com/topic/235292-modmic-40-static-noise/#findComment-3224100
https://linustechtips.com/topic/235292-modmic-40-static-noise/#findComment-3224228
