So I just picked up a Corsair Carbide 300R for my upcoming build. While the build quality is solid and it feels like I could load it up without worrying about the case flexing, I did notice one thing that concerned me a bit: the side panels don't seem to sit completely flush. Any other 300R owners run into this problem? Any remedies/suggestions? It's not a huge concern, but I don't want the case's airflow to be potentially hindered by loose panels.
Thinking of building a rig soon
https://linustechtips.com/topic/234540-300r-side-panels/
I setup my friends 300R (After replacing his shitty 1 exhaust no intake case lol) and I had no issues with the side panel flexing. I doubt it will affect airflow that much and at most it will have a slight air leak.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/234540-300r-side-panels/#findComment-3210201
