DisplayPort versions question
By
Guest
in Displays
in Displays
Solved by slashes_2_asses,
It is backwards compatible, but you will not have any DP1.2 features.
Source: I have a Dell U2413 with a DP1.1 graphics card. The monitor also has feature to turn off DP1.2, ,so it behaves as DP1.1 if you have any trouble.
voltigeurramon ·
Posted in Troubleshooting0 -
Vibora ·
Posted in New Builds and Planning4 -
4
3
Doctah ·
Posted in Peripherals2 -
6
michaelb198 ·
errorcode123_dindin1 ·
Posted in Graphics Cards5
