Water cooling setup for gaming rig
The waterblock you linked is a GTX Titan block and would not fit your graphics cards.
Koolance Triple 140: $80
Alhpacool NexXxos Monsta Dual 120: $77
EK D5 X-RES Top 100: $148 (or anything with a D5 pump)
EK Supremacy EVO CPU waterblock: $75
EK GTX 780 waterblock x2: $216
Tubing, fittings and coolant: ~$80
This list comes in a little higher (around $650) but you could cut costs a little by getting a kit from XSPC/EK/Alphacool that comes with a 240mm rad, but you'd have to find one that comes with a non-5.25 bay res/pump.
To be honest, unless you a really unhappy with your CPU temps, I would just get two more 120/140mm AIO watercooling system and a NZXT Kraken G10 (or Corsair HG10 when it comes out) graphics card brackets. I have two NZXT X61 AIO watercooling systems in my system and a full custom loop costing a few hundred dollars more would likely only reduce my temps by about 3-4*C.
