Benchmarking Help
Go to solution Solved by heineygoat,
All I had done between the two benchmarks was install Display Fusion. So I killed the program and re-ran the test. Problem solved.
Wow I can't believe that,
running DS in the background = 600fps
without DS = 2000fps
Yesterday I ran Novabench a few times and consistently got a score in the 1900's.
Today I run Novabench and consistently get a score in the 1300's.
My Graphics Test score is getting about 600 less, no hardware changes at all?
“Snorting instant coffee is the best,” said Kayla Johns, 19, of Portland.
https://linustechtips.com/topic/23168-benchmarking-help/
https://linustechtips.com/topic/23168-benchmarking-help/#findComment-293187
