there are a ton of good cases for around this price here in america(conversion is to around 100 usd) not sure on availability though
corsair 600t, msi z87-g45, intel 4770k, 16g patriot viper low-pro ram, asus direct cu2 780, crucial 256gig ssd, seagate baracuda 1tb,
https://linustechtips.com/topic/230636-help-me-choose-a-case/#findComment-3155965
https://linustechtips.com/topic/230636-help-me-choose-a-case/#findComment-3156001
I would recommend a mid tower. If you are trying to stay around 100 I would recommend something like a Raidmax Super Helios (side window and blue led fans) coming in at 81 usd. Or you can check out some of the NZXT phantom series which come in at a pretty good price, and have nice ascetics.
https://linustechtips.com/topic/230636-help-me-choose-a-case/#findComment-3156042
do you have size preference? mid tower, full tower? at that price it seems mid tower is going to be it
 choice is a bit limited here, but mid tower it is, how about spec 03??
https://linustechtips.com/topic/230636-help-me-choose-a-case/#findComment-3156212
