I have the B85M (not the Pro) with an i3 and for what im using it for its a good board
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
https://linustechtips.com/topic/230098-asrock-b85m-pro3/#findComment-3149281
should be fine, what are you doing with it? (gaming, editing, etc )
https://linustechtips.com/topic/230098-asrock-b85m-pro3/#findComment-3149331
Should be ok with a good GPU....you wont be overclocking, so i think it would be a good buy
https://linustechtips.com/topic/230098-asrock-b85m-pro3/#findComment-3151956
