Just a little help!
Solved by TheRunningOtaku,
So yeah, I shouldnt run into any problems? Or I might?
you shouldn't! It's just a shame that it isn't the best value
Maybe if you need a HTPC in the future you could use the APU for that
Worried that it might be bottlenecked, but I don't think it'll be by much, especially if you OC the APU.
You should look for a 280, or 285 (285 has similar performance and price, but lower TDP and updated feature set)
