You can, I wouldn't say it's ideal though.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
Ok. What would be ideal? I am using a Phanteks Luke case.
The 420 would be getting there, heck it's adequate if you're not expecting sub 60 degree temps under load. A 420 Alphacool XT45 can dissipate about 300W of heat. Add another 240 or 280 in the front and you're golden.
Bert & Ernie before squirting spermie.
