Logitech speakers #help
Hi  ,
so i really need new speakers ,
and it has to be from logitech and 2.0-speakers
im going to use them for gaming.
Logitech Z200
Logitech Z130
Logitech Z150
please help me out what is the best speaker for gaming and has the best sound.
i've seen some reviews and i think the Z200 is the best one  .
thnx  ,
https://linustechtips.com/topic/225122-logitech-speakers-help/
Well yeah the Z200 would be the best, but why only Logitech?
https://linustechtips.com/topic/225122-logitech-speakers-help/#findComment-3083893
i have a full logitech setup  ;)
the z200 would fit nice thnx for your advice
Haha ok :D np
https://linustechtips.com/topic/225122-logitech-speakers-help/#findComment-3084273
https://linustechtips.com/topic/225122-logitech-speakers-help/#findComment-3085133
hmm thnx for the info
what would you suggest me
im on a 100 dollar budget
thnx  ,
The pricing and availability in the Netherlands is pretty different from the US. I could help you out more if you give me a website to look through but you could probably find a good Edifier in your price range.
https://linustechtips.com/topic/225122-logitech-speakers-help/#findComment-3085650
