iam planing on getting the Cooler Master Hyper 212 EVO. i want to over a 3570k. i ve heard of people reaching 4.5 using push pull. does the push pull help? i saw linus video on the h100i, but i didnt know if push pull would help because the Cooler Master Hyper 212 EVO is a small
thx
https://linustechtips.com/topic/22487-cooler-master-hyper-212-evo-push-pull/
I have my 212 EVO running my 3570k at 4Ghz on silent mode, and the hottest core read 70c running prime95 for 30 minutes.
I'm sure you could push it to 4.5Ghz easy without the need for another fan.
Don't know about the stock fan, but something like a Noctua NF F12 (as replacement) would probably be a better upgrade to it.
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
I have a 212 EVO and I dumped the stock fan and put Corsair SP120 quiet edition fans in push/pull. I can get to 4.7 GHz/1.35V stable at around 55 degrees full load on my 2700K. However I rarely run it at that and generally it stays around 25-30 degrees idle. 4.5 will probably be attainable on your chip with the stock fan on the 212 EVO. Only one way to find out :)
MSI Z68A-GD80 (G3) | Core i7 2700K @ 4.7GHz | EVGA GTX 580 1.5GB @ stock
8GB G.Skill RipjawsZ 2133MHz | OCZ Agility 3 60GB | 3x500GB RAID 5 | DVD-RW
Xclio Nighthawk | OCZ ModX Stream Pro 700W | CM Hyper 212 EVO with Corsair SP120s push/pull
