Both of your URL's are linked to the AMD
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
https://linustechtips.com/topic/224056-help/#findComment-3069011
The performance is practically the same so it's preference, I would go with the Intel
https://linustechtips.com/topic/224056-help/#findComment-3069072
well... i prefer intel (i'm oldschool , nvidia + intel or amd + well amd :P )
I7 3930K @4.4 GHz  /  Asus rampage 4 formula  / 4x 8gb kingston hyperx blue low profile / gtx 980  / 2x ssd 500gb samsung 840 / 500gb 840evo ssd   /  500 GB WD blue /  windows 7 ultimate
my build: http://linustechtips.com/main/topic/133477-750d-finished/
https://linustechtips.com/topic/224056-help/#findComment-3069273
the i5 4690k would theoretically be better for gaming and the fx 8350 would theoretically be better for editing and multi-core extensive workloads. Although i would personally get the i5 because i feel like the intel one will last you longer.
P.S: All personal bias aside, get the one you feel is right for you.
https://linustechtips.com/topic/224056-help/#findComment-3069287
cant you upgrade the mobo and cpu (noob question)
https://linustechtips.com/topic/224056-help/#findComment-3069423
you can allways swap out your mobo & cpu, but you have to do a format when you do it. The best thing to do is to pick a socket you want to end up with and buy a lower end cpu for that socket and only upgrade the cpu when you have the money. Because you don't want to end up with a lot of spare parts :P
https://linustechtips.com/topic/224056-help/#findComment-3069525
Thanks
https://linustechtips.com/topic/224056-help/#findComment-3069547
