i5 4690k and Water cooling
Okay so i am not planning to overclock alot, because i am new to overclocking. I just want a good futureproof all in one watercooling. I am maybe going to buy an i7 in the future.
But what about the Corsair H75? Its only 1 fan and alot smaller
I also want a quiet pc, and the more fans, the lower rpm they need to run at
But Thanks for the answer anyway
Please write back about the H75
The H75 should do just fine for your needs. The Kraken x41 is a 140mm rad and fan option that is a little more expensive but performs roughly on par with 240mm options because of the increased radiator thickness compared to other AIO systems.
As above.
You can run your cpu with stock cooler(it's no AMD, lol).
I was considering futureproofness when I hinted at a custom solution.
IIRC there is an AIO solution that also allows for addons on market; but I don't remember the name.
There is the Swiftek H220X, which allows for custom expansion and tubing/fluid changes. But it is much more expensive. The brand new Fractal Designs AIO systems are also expansion ready but they will be EU only for a while.
