power supply fan problem
By
jojocool111
in Power Supplies
in Power Supplies
Solved by Daigo,
Yes you can but the "perfect" thing to do its to weld the new fan or use the existing wiring on the PSU reusing the header. ( if the fan ifs not simply joined to the pcb )
Like in this video but the Seasonic 750w don't really help to identify the exact model you have, so if you bought it recently just RMA it.
voltigeurramon ·
Posted in Troubleshooting0 -
Vibora ·
Posted in New Builds and Planning4 -
4
3
Doctah ·
Posted in Peripherals3 -
8
michaelb198 ·
Posted in Peripherals2
