having some problems with internet speed
Solved by guas5373,
First, I suggest doing a wired test on the router itself to see if you are actually able to get your advertised speed. If you are able to get your advertised speeds, then I suggest moving onto to upgrading your wireless adapter or possibly even upgrading to power line adapters. They are fairly simple to use and give you better speeds and less latency than wireless, but not as good as Ethernet of course. Hope this helps.
