Ok so although i have a pc i still would really like to get an original xbox, for the awesome games that i grew up with as a kid. With that said i can not seem to find a way to get it to work on a monitor. So my question is there a way to do this or not, if so please explain how. Thanks!
I run my own indie game company called Color Dragon Studios where we are currently making a 2d platformer game called Small Earth.
https://linustechtips.com/topic/221085-need-help/
You should be able to get a signal converter box from somewhere
CPU Intel i7 3770K | Motherboard ASUS Z77 Sabertooth | RAM G.Skill Ripjaws Z 16GB(4x 4GB) | GPU ASUS GeForce GTX 680 DirectCU II TOP | Case Thermaltake Overseer | Storage Samsung SSD 500GB 850EVO, WD Caviar Black 1TB | PSU Cooler Master Silent Pro M2 Series 1000W | Display(s) ASUS PB278Q 27", 2x Samsung LS22C45KBW 22" | Cooling Corsair Hydro Series H75 | Keyboard Razer Lycosa | Mouse Razer Lachesis | Sound Dell speakers a525 2.1, Razer Kraken 7.1 | Operating System Windows 7 Professional
https://linustechtips.com/topic/221085-need-help/#findComment-3030917
is that what it would be called, and do you have any ideas of where i might be able to get one?
https://linustechtips.com/topic/221085-need-help/#findComment-3031206
A google search would give you a good idea as to where they are available in your region
https://linustechtips.com/topic/221085-need-help/#findComment-3031360
alright thanks. Also do you think this would work:
http://www.amazon.com/gp/product/B008S7EYW2/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=A2WXIT89T9GC4E
Also i would use a hdmi to dvi adapter.
https://linustechtips.com/topic/221085-need-help/#findComment-3031465
I'm going to say a very confident maybe. The reviews tend to be a bit of a mix but it tends to work well most of the time unless you get a dud
https://linustechtips.com/topic/221085-need-help/#findComment-3031860
