Up till now i've only ever OC'd my CPU. I decided to OC my GPU a bit today, see what i can squeeze out of it. I've got an MSI R9 270X.
Stock speeds -
1050 MHz Core
1400 MHz Memory (5.6GHz)
My OC -
1165 MHz Core
1500MHz Memory (6GHz)
My GPU's core temp is safe, running Furmark it hit 71c with my fans at 47%.(i have a custom fan profile in MSI Afterburner) The thing is, my VRM temps went up to 88c.
Considering a regular game won't cause it to hit a high temp like that, compared to Furmark. Is that a reasonable VRM temp, considering i've OC'd the memory too?
*Update*
VRM's are sitting at ~50c whilst i play CSS, seems alright. May just have been Furmark causing them to get to those high temps.
VDDC sits around 1.24v
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/220954-vrm-temps/
Yeah sounds about right, my 290x lightning VRM runs at 75 degrees after gaming. So it should be fine for gaming.
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
https://linustechtips.com/topic/220954-vrm-temps/#findComment-3028954
VRM can get really hot when overclocking considering you are applying more voltage. You can try to benchmark you gpu by lowering the gpu voltage to the sweet spot or apply new thermal paste to your gpu
Why do you think i was running Furmark? The voltage is stock, but i've increased the power limit in MSI Afterburner to +20%.
https://linustechtips.com/topic/220954-vrm-temps/#findComment-3028983
What I mean is manufacturer usually over set the stock voltage more than it really needed. So, if you are really paranoid about temperature, you can lower the voltage.
https://linustechtips.com/topic/220954-vrm-temps/#findComment-3029179
