What is the typical temps of a 4670k stock clock and voltages with a hyper 212evo? On a burn test I am averaging 75 degrees and 45 degrees at idle. Now I know the 212 isn't a crazy cooler but does that seem a little high? Seems closer to an intel stock cooler in terms of performance rather than the 212.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/220395-hyper-212-evo-temps/
shouldn't go past 60
unless you are using Prime95. Then 70ish is ok, though your airflow seems to be suboptimal.
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021174
If you haven't overclocked and assuming your ambient temp is average, I would say thats pretty high, re-mount the cooler and try again
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021210
I figured as much, not too sure what went wrong. I will see if that helps. It's running at 65C while running around bf4 test range. Too high.
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021232
That does seem like it's a little too high.  The temperatures should be lower, however that much depends on your ambient and case temperatures.
Things you can try include remounting the cooler and make sure you apply the correct amount of thermal paste while doing so, make sure your case airflow is good and while you are at it clean off any dust that's inside your PC.
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021293
Check out my Review With Statistics of the 4670k + Hyper 212 EVO.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021345
BEHOLD! IN ALL OF MY INFINITE IDIOCY I GIVE YOU THE CULPRIT. Yeah... im stupid I didn't peel it off the heat sink... Burn tests dropped down to 55C. Now I will try to hit 4.2Ghz at the very least until I can get my liquid cooling replaced. Thank you for the replies anyway and I hope that gave you a laugh at least.
post-39055-0-78096800-1411419931_thumb.j
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021494
BEHOLD! IN ALL OF MY INFINITE IDIOCY I GIVE YOU THE CULPRIT. Yeah... im stupid I didn't peel it off the heat sink... Burn tests dropped down to 55C. Now I will try to hit 4.2Ghz at the very least until I can get my liquid cooling replaced. Thank you for the replies anyway and I hope that gave you a laugh at least. images.jpeg
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021511
Haha, brilliant!
I'm glad you've fixed it now.
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021541
Haha, brilliant!
So at 1.275V and 4.4ghz I am getting about 84C max in a burn test. When I was liquid My temps were about 65. Should it be stable at the same Voltage even though the temps are higher? I not too experienced in overclocking.
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021581
this is going in the Hall of Fame!
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021634
seems fine to me. 1.275V is quite a bit and Haswell runs hot. Then again, I never had an Evo
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021641
It should still be stable.
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021646
My chip isn't a fantastic overclocker. I can't even get 4.5ghz at 1.38V. But 4.4ghz is stable at 1.275V but I am just waiting to RMA my h110.
https://linustechtips.com/topic/220395-hyper-212-evo-temps/#findComment-3021711
