300r cooling tips
I have the same case with a single 7770 Vapor-X and under load I am getting 50c - 55c. Because you have two, that does restrict the air flow a little so it is understandable that you are running a little hotter.
Make sure that you are getting as much airflow in at the front as you can. This will be your main source of airflow in. Especially if you have 2 140mm fans on the front like me.
As you know heat rises. And if you are inputting air from the top, that isn't as efficient as it could be. I would have a single 120 (or 140 would be better) at the top as an exhaust and have your h60 at the top as well. I know the 300r has relatively decent space at the top for a h60 so it should work. I haven't got any fans on the side of my case because I read that it would create clashing airflow as inputs and would exhaust the cool air coming from the front even before it has reached the main parts of the PC to cool. Experiment with it and see what temps you are coming up with.
