Hey there! I'll start off by posting specs of my current rig.
Mobo - Gigabyte GA-990FXA-UD3 (rev 4.0)
PSU - Corsair CS750M (750w gold rated)
CPU - AMD FX 8350 OC'd @ 4.92ghz (with Phanteks Ph-tc14pe dual tower cooler)
RAM - Corsair Vengeance 16gb 1600mhz (4x4)
GPU - AMD HD7970 ghz ed
Case - Coolermaster Haf X
My budget - £1000
The main reason I want to upgrade is that I do a lot of 3D rendering and work with graphic software such as Adobe Photoshop. I feel that the FX-8350 is really starting to show its age right now as at times rendering can be a bit of a pain during deadlines for my university projects when I need things to be running snappy.
In terms of gaming the current setup is fine at 1080p resolutions, however I'm planning on upgrading my monitor soon to a 1440p one and I feel the 7970 might struggle to keep a stable 60fps on most of the newer game titles on high-ultra setting anyway.
Thats pretty much it really. I'd like suggestions on new parts that would suit my needs also is it worth going water-cooled and would I need a different case for that or is my current cooler/case sufficient.
Thanks guys :)
https://linustechtips.com/topic/217195-need-help-on-new-rig/
If it fits your budget go with 2011 soket 6 core i7, + 32gb ram or even more if finances allow you & GTX titan black
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/217195-need-help-on-new-rig/#findComment-2977982
I'd recommend a hex-core core i7 with either the 780ti or Titan Black.
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/217195-need-help-on-new-rig/#findComment-2978069
